Gene , yes the wires was remove , also there were 120v at both elements
w2002s,
Check if there is 120VAC between the red wire (R-1 on the wiring diagram) at the control board and ground. If the reading is wrong then one of two 120VAC legs to the oven is missing. It could be the circuit breaker or a broken wire.
Gene, I check R1 to ground there is 120 v. from BLK 6 to ground at the control 120v . 240v going in.
w2002s,
There is proper power to everything in the oven, according to your reports. You just replaced the EOC.
The oven is still not working with unknown error code -1- which I never heard for all my life. Double check all electrical connections and components and if there is nothing wrong, call a certified technician.
my crosley gas range wouldn't come up to temp. I replaced the complete clock/relay and things worked fine. Now working for 3 months and an F1 error code comes on approx once a day and beeps? In the middle of the night when the oven is non operational. Can anyone help?:mad:
Hi Monk,
What is the complete model number of the range?
Gene. Hi Gene, Crosley CG3478XRW s/n 14C328109284 Thx, Monk
Hi Monk, Most likely the problem is a bad touch pad. - The part number for the control panel is AP304866 Here are the break down diagrams for the Crosley range Model CG3478XRWGene.
i have a thermodor sc302tb double wall oven with a f2 error code. i called thermodor and they are no help. do you have any suggestions
The "F2" error code means "temperature runaway detected by the control".
For which oven, upper or lower, the error code was shown?
In which mode: time of the day, cooking or self cleaning the error code was shown?
