dot loughner
#1 Posted : Monday, June 16, 2008 4:19:10 PM(UTC)
dot loughner
After cleaning my oven the last time the clock wouldn't work. Recently when I tried to set the cleaning cycle I could not get it to work. Would this problem be due to the clock not working and therefore not able to set the start and stop time?
#2 Posted : Tuesday, June 17, 2008 1:26:57 PM(UTC)
Can you be more specific on what happened when you tried to set the self clean?
What happened if you tried to use Bake or Broil?
dot loughner
#3 Posted : Wednesday, June 18, 2008 8:47:50 AM(UTC)
dot loughner
When I tried to set my self cleaning oven-I discovered the clock is not working therefore I was not able to set a start and stop time and the oven cleaning lights don't come on.
The oven works fine with baking and broiling.
dot loughner
#4 Posted : Wednesday, June 18, 2008 8:51:25 AM(UTC)
dot loughner
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#5 Posted : Wednesday, June 18, 2008 12:14:50 PM(UTC)
Open the control panel and check all wires connected to the clock. If there is nothing wrong then the clock has to be replaced. Unfortunately the new clock for your range are no longer available but you can try to rebuild the old clock through PCBR.BIZ
dot loughner
#6 Posted : Thursday, June 19, 2008 6:16:08 AM(UTC)
dot loughner
How do I gain access to the control panel to check the clock wires? Also what does PCBR . BIZ stand for?:confused:
#7 Posted : Thursday, June 19, 2008 11:01:01 AM(UTC)
Here are the break down diagrams for the Amana range Model MRR-1000. I hope it will help you to figure out how to take the control panel apart.
PCBR.BIZ is the URL for the web site of the company which does such job.
Guest (8)
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
Whirlpool electric range GR563LXSS (Oven Repair (including Ranges and Cooktops))
by longtimealaskan 3/6/2023 9:47:00 PM(UTC)
Samsung electric range bake and broil do not work (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 2:07:19 PM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Westinghouse Electric Range Model KF341R (Appliance Parts)
by GEman 5/28/2022 9:09:03 AM(UTC)
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
Frigidaire LGEF3043KFM Electric Range Uneven Heat (Oven Repair (including Ranges and Cooktops))
by Asweateria 2/27/2022 9:32:41 PM(UTC)
Samsung electric range (Oven Repair (including Ranges and Cooktops))
by MELLIOTT 2/8/2022 6:38:17 AM(UTC)
LG Electric Range Overheating (Oven Repair (including Ranges and Cooktops))
by jenvee 1/25/2022 7:20:52 AM(UTC)
kenmore electric range 79097459802 (Oven Repair (including Ranges and Cooktops))
by Melissadimas 1/9/2022 9:07:08 PM(UTC)
replacing latch, door on Kitchen Aid electric range series II (Oven Repair (including Ranges and Cooktops))
by WSCHUMANN 7/12/2021 6:02:36 AM(UTC)
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 5/7/2021 9:58:17 AM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
