dot loughner
#1 Posted : 17 years ago
dot loughner
After cleaning my oven the last time the clock wouldn't work. Recently when I tried to set the cleaning cycle I could not get it to work. Would this problem be due to the clock not working and therefore not able to set the start and stop time?
#2 Posted : 17 years ago
Can you be more specific on what happened when you tried to set the self clean?
What happened if you tried to use Bake or Broil?
dot loughner
#3 Posted : 17 years ago
dot loughner
When I tried to set my self cleaning oven-I discovered the clock is not working therefore I was not able to set a start and stop time and the oven cleaning lights don't come on.
The oven works fine with baking and broiling.
dot loughner
#4 Posted : 17 years ago
dot loughner
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#5 Posted : 17 years ago
Open the control panel and check all wires connected to the clock. If there is nothing wrong then the clock has to be replaced. Unfortunately the new clock for your range are no longer available but you can try to rebuild the old clock through PCBR.BIZ
dot loughner
#6 Posted : 17 years ago
dot loughner
How do I gain access to the control panel to check the clock wires? Also what does PCBR . BIZ stand for?:confused:
#7 Posted : 17 years ago
Here are the break down diagrams for the Amana range Model MRR-1000. I hope it will help you to figure out how to take the control panel apart.
PCBR.BIZ is the URL for the web site of the company which does such job.
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 12 months ago
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 about a year ago
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 2 years ago
Whirlpool electric range GR563LXSS (Oven Repair (including Ranges and Cooktops))
by longtimealaskan 2 years ago
Samsung electric range bake and broil do not work (Oven Repair (including Ranges and Cooktops))
by Guest 2 years ago
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 3 years ago
Westinghouse Electric Range Model KF341R (Appliance Parts)
by GEman 3 years ago
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 3 years ago
Frigidaire LGEF3043KFM Electric Range Uneven Heat (Oven Repair (including Ranges and Cooktops))
by Asweateria 3 years ago
Samsung electric range (Oven Repair (including Ranges and Cooktops))
by MELLIOTT 3 years ago
LG Electric Range Overheating (Oven Repair (including Ranges and Cooktops))
by jenvee 3 years ago
kenmore electric range 79097459802 (Oven Repair (including Ranges and Cooktops))
by Melissadimas 3 years ago
replacing latch, door on Kitchen Aid electric range series II (Oven Repair (including Ranges and Cooktops))
by WSCHUMANN 4 years ago
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 4 years ago
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
