2 Pages12>
Ramos
#1 Posted : Monday, May 19, 2008 9:23:48 AM(UTC)
Ramos
I would like some help is being able to tighten the spin belt on this magtag washer, can some one UserPostedImageplease help
ApplianceJunk
#2 Posted : Monday, May 19, 2008 10:06:12 AM(UTC)
ApplianceJunk
The idler wheel is self adjusting. There is no way to tighten the belt.
#3 Posted : Monday, May 19, 2008 1:31:14 PM(UTC)
I would remove the belt and turn the transmission pulley both ways to see if one direction is tight, if ok, check the pump for bad bearings. If everything ok, just replace the belt.
Ramos
#4 Posted : Tuesday, May 20, 2008 8:52:03 AM(UTC)
Ramos
Thanks for your help yesterday, I did see that there is not way to adjust the belt, also, I what I found was that the pulley wheel was at the bottom of the cabinet. My question is there some way to fasten the pulley wheel to the pulley lever? I managed to get the pulley wheel back in place but it will not stay there on it's own.
Thanks again for your help
Ramos
Ramos
#5 Posted : Tuesday, May 20, 2008 9:42:30 AM(UTC)
Ramos
thanks for you help, can you tell me if there is a way to fasten the pulley wheel to the lever idler arm??
Again thanks for all the help.
Ramos
Ramos
#6 Posted : Tuesday, May 20, 2008 9:43:54 AM(UTC)
Ramos
thanks again, I need to know if there is a way to fasten the pulley wheel to the lever idler arm??
Ramos
Ramos
#7 Posted : Tuesday, May 20, 2008 9:57:08 AM(UTC)
Ramos
Iam not sure if you are getting my replies. I would like to know if there is a way to fasten the pulley wheel to the lever idler arm. I found the pulley wheel on the bottom of the cabinet, put it back in the lever idler arm but I am not sure if it will stay with out some way to fasten it.
Thanks for you kindly help.
Ramos
#8 Posted : Tuesday, May 20, 2008 10:49:51 AM(UTC)
The "C" clip/retainer ring may have popped off the idler shaft, just look for it, or the pulley may be bad. C clip part # 23748, pulley part # 40045001
Ramos
#9 Posted : Wednesday, May 21, 2008 8:42:52 AM(UTC)
Ramos
thanks again, I will look for the the c retainer.. If not I may have to order one
Ramos
budney
#10 Posted : Thursday, October 2, 2008 7:13:15 AM(UTC)
budney
My neptune washer model MAH3000AWW makes a high pitch whirling sound during the final spin cycle. I think the bearing for the inner tub is going bad but I can not find a bearing on your parts breakdown.
Thanks russ rlney@msn.com
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
2 Pages12>
