13 Pages«<56789>»
David Casparian
#61 Posted : Monday, March 29, 2010 11:01:13 AM(UTC)
David Casparian
Hi Gene -
I am starting to run tests and am coming up with "check the motor thermal cut out" - not really sure where to locate/test this. Please let me know when you have a moment.
Thanks,
David
#62 Posted : Monday, April 5, 2010 8:35:36 PM(UTC)
Hi David,
Sorry for the delay.
Can you post the tech sheet? The best way is to scan it and attach it to your reply.
David Casparian
#63 Posted : Tuesday, April 6, 2010 8:03:37 AM(UTC)
David Casparian
Gene -
Attached are all diagrams for my model. I have tested, and retested the motor thermal cutoff, timer switch, etc. and am totally stuck. I'm not giving up, but sure would like to buy a part and fix this pup!
Thanks for your help,
David
File Attachment(s):
131806900.pdf (2,036kb) downloaded 15 time(s).
EARLY Gallery SPEED CONTROL page 1.pdf (120kb) downloaded 14 time(s).
EARLY Gallery SPEED CONTROL page 2.pdf (106kb) downloaded 5 time(s).
#64 Posted : Tuesday, April 6, 2010 11:07:27 AM(UTC)
David,
Post the results of all tests you've performed.
David Casparian
#65 Posted : Tuesday, April 6, 2010 3:27:07 PM(UTC)
David Casparian
On the tech sheet (Early Gallery), page 1, results as follows..
#1 Drain pump runs
#2 Motor does not run
#3 Meter reads zero; motor thermal cut out zero
#4 Meter reads zero.
This is about as far as I got - except for these tests:
Motor pin 7 to 4 pin on 4 plug = .130-.160
Motor pin 8 to 4 pin on 4 plug = .000
#66 Posted : Friday, April 9, 2010 10:00:52 AM(UTC)
Originally Posted by: David Casparian Go to Quoted Post
...#3 1/ Meter reads zero;...
2/ ...motor thermal cut out zero
How did you check in 2/ - did you measure voltage or resistance?
If there is zero Ohms, then the problem is a bad speed control board.
- The speed control board Part number: AP2107536
David Casparian
#67 Posted : Friday, April 9, 2010 1:28:02 PM(UTC)
David Casparian
Thanks Gene.
I have a tech here now. He has replaced the door switch and that did not solve the problem. It seems maybe he wasn't that good at testing as I told him to test the thermal motor cutout
David Casparian
#68 Posted : Friday, April 9, 2010 1:43:51 PM(UTC)
David Casparian
Maybe there is no contact at 11 to 11a - the timer switch? The tech is coming back tomorrow (Sat). Why don't you just come out here and fix it Gene? (I'm kidding)
#69 Posted : Friday, April 9, 2010 3:17:13 PM(UTC)
I'll be glad to help you out there if you pay the trip charge :).
If the drain pump runs then there is nothing wrong with the door switch.
It seems to me like the problem is a bad speed control board, especially because the motor thermal cut out tests OK.
It's easy to check the timer in accordance with the diagrams on page 2 of the Tech sheet you posted to excluded it from the list of suspects.
David Casparian
#70 Posted : Saturday, April 10, 2010 10:47:41 AM(UTC)
David Casparian
Thanks again for your help. I think I've been pushed over the edge and should buy a new machine. I talked to a different tech who said that the bearings go out on these machines after about 10 years, and my machine has a build date of 1/99.
The SCB is approx $300 and as much as I'd love to keep this machine, I'm just not convinced it's a wise move.
Guest (9)
ge front load washer won't tumble/spin (Washer Repair)
by Laeloni 3/26/2011 10:07:27 AM(UTC)
13 Pages«<56789>»
