FixingIt
#1 Posted : Tuesday, April 8, 2008 2:41:14 PM(UTC)
FixingIt
I have a Frigidaire side by side. Over this past weekend I had to get into the freezer to unfreeze the drain plug. After I have put it all back together, now the front panel will not work. I get no ice, water, or light. The ice maker is still making ice though so I suspect it may be electrical. Any suggestions on where to start?
gearhead1218
#2 Posted : Tuesday, April 8, 2008 3:49:31 PM(UTC)
gearhead1218
At the bottom of the freezer door going thru the hinge is the wiring harness for the dispenser system. that harness should plug into another harness right there in the same area. Check that plug. Either that or you have a broken wire which if it's in the door would mean a new door, since the harness is molded into the door.
#3 Posted : Tuesday, April 8, 2008 6:52:29 PM(UTC)
Hi FixingIt,
The first thing I would check is the dispenser switch (#125 on the controls break down diagram) on the freezer control panel.
- The part number for the dispenser switch is AP2110937
Here are the break down diagrams for the Frigidaire refrigerator Model FRS24ZSGB0
FixingIt
#4 Posted : Saturday, April 12, 2008 10:09:06 AM(UTC)
FixingIt
Where is this located? In the back or in the freezer compartment?
FixingIt
#5 Posted : Saturday, April 12, 2008 2:02:42 PM(UTC)
FixingIt
I found the spot, but that was not it. It was the wiring harness at the bottom of the freezer door. Two of the leads were not connected so I spliced them and viola.
Thanks for the suggestions.
#6 Posted : Saturday, April 12, 2008 3:07:30 PM(UTC)
I'm glad you were able to fix it.
Frigidaire side by side - warm freezer cold fridge - help please (Refrigerator & Freezer Repair)
by Doug427 1/23/2023 4:36:18 PM(UTC)
Ice Dispenser on Frigidaire side by side pulses when dispensing ice (Refrigerator & Freezer Repair)
by JordanNolan 1/8/2023 8:50:08 AM(UTC)
Frigidaire side by side door fridge- timer question (Refrigerator & Freezer Repair)
by Chickadee 10/3/2016 5:00:58 PM(UTC)
Frigidaire Side By Side Compressor Will Not Start (Refrigerator & Freezer Repair)
by stockler707 7/17/2015 5:56:31 AM(UTC)
Frigidaire side by side, freezer temp erratic, fresh is ok (Refrigerator & Freezer Repair)
by nigelquest 12/27/2014 10:47:11 AM(UTC)
Frigidaire Side by Side not cooling (Refrigerator & Freezer Repair)
by mrmagic 12/2/2014 10:13:52 AM(UTC)
Frigidaire Side By Side not cooling to set temp (Refrigerator & Freezer Repair)
by Jedi.Cowboy 11/26/2014 6:48:31 AM(UTC)
Frigidaire side by side won't defrost (Refrigerator & Freezer Repair)
by scmiller 11/13/2014 9:06:57 AM(UTC)
Frigidaire side by side not cooling may be defrost problem (Refrigerator & Freezer Repair)
by ScotB48116 8/5/2014 9:29:43 AM(UTC)
Frigidaire side by side ice maker/freezer issues (Refrigerator & Freezer Repair)
by franchz 7/16/2014 6:20:00 PM(UTC)
Frigidaire side by side not cooling properly (Refrigerator & Freezer Repair)
by RodH508 7/6/2014 10:48:38 AM(UTC)
Frigidaire Side by side fridge not cooling properly (Refrigerator & Freezer Repair)
by Lebbrin 1/1/2014 1:24:48 PM(UTC)
Frigidaire side by side refrigerator not cooling (Refrigerator & Freezer Repair)
by ducatiduke 12/22/2013 8:42:21 PM(UTC)
Frigidaire Side by Side Running 24/7 (Refrigerator & Freezer Repair)
by jhknight 9/8/2013 7:37:01 PM(UTC)
Frigidaire side by side Freezer not Freezing (Oven Repair (including Ranges and Cooktops))
by ac132675 7/25/2013 10:24:45 AM(UTC)
