Ted
Ted
#1 Posted : Monday, March 24, 2008 10:02:15 AM(UTC)
Ted
the agitator seems to be stripped. It spins freely in either dirction when not in use and does not agitate when machin is operational. You can hear it lightly grinding as the inside assembly rotates but the agitator does not.
#2 Posted : Tuesday, March 25, 2008 9:27:39 AM(UTC)
Hi Ted,
The agitator consists of two major parts: the bottom part called "agitator" and the top part called "auger".
If the auger moves freely in both directions then the problem is a bad agitator clutch dogs (#5 on the break down diagram).
If the agitator does it then the problem is a worn out splines inside the agitator or on the gear case shaft.
Most likely the problem with your washer caused by a bad agitator clutch dogs. In order to fix it you have to use the agitator repair kit.
- The part number for the agitator repair kit is AP3094520
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Restricted airflow after repairman installed new blower wheel (Dryer Repair)
by Guest 6/1/2024 5:28:38 PM(UTC)
Water tube disconnected (Refrigerator & Freezer Repair)
by Guest 5/31/2024 11:41:13 AM(UTC)
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl 4/23/2024 7:59:18 AM(UTC)
Opened lid to add something to washer after it started and now the cycle won’t start again (Washer Repair)
by Guest 2/25/2024 6:18:56 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
GE fridge water dispenser slows to trickle, speeds up when filter is twisted (Refrigerator & Freezer Repair)
by Guest 1/11/2024 5:03:35 AM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
Ge Monogram Integrated Top/Bottom Not Cooling ZICP360NXLH (Refrigerator & Freezer Repair)
by grundyv2 10/7/2023 12:48:51 PM(UTC)
Kenmore 665.17032403 Doesn't cycle to the heated dry cycle (Dishwasher Repair)
by breckrider 5/10/2023 8:01:43 AM(UTC)
Thermal fuse blown repeatedly (Dryer Repair)
by Guest 3/5/2023 6:13:36 PM(UTC)
Kitchenaid Control panel melted (Dishwasher Repair)
by Guest 12/9/2022 2:41:47 PM(UTC)
Downdraft range converted to ductless (Oven Repair (including Ranges and Cooktops))
by Guest 8/26/2022 11:42:42 AM(UTC)
LG fridge not cooling - freezer and ice maker fine - doesn’t look to be defrost related either (Refrigerator & Freezer Repair)
by Guest 7/25/2022 6:04:54 PM(UTC)
fan blade melted (Microwave Repair)
by chis 6/1/2022 9:32:50 AM(UTC)
