AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
GE fridge water dispenser slows to trickle, speeds up when filter is twisted
Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I've got a GE fridge (GEPSW26SGPASS) that is working well overall, but recently the water dispenser has slowed to a trickle -- but that trickle turns back to full power if I give the filter bypass a couple twists. I've already replaced the Water Inlet Valve (thanks for the parts and video, AppliancePartsPros!) and replaced my GE MWF filter with a newly purchased filter bypass. The first time I did this the water came out full steam and I thought it must have been the filter. But an hour or so later, the water was back to a trickle. I took out the bypass, checked it to see if it was okay, then put it back in. Water back to full strength. Then a little while later, the water back to a trickle. I went in and gave the filter bypass a few twists, out and then back in, and magic presto full power again. But only temporarily. What the heck? It's almost like there's a problem with the valves (or something) there where the filter is? Is this a known thing? Any ideas for a more permanent solution? Dave Edited by user Thursday, January 11, 2024 5:05:39 AM(UTC)
| Reason: added clarification that further twists fix it every time
