william clegg
#1 Posted : Tuesday, January 12, 2010 8:08:57 PM(UTC)
william clegg
Washer is making like a squeaky noise during washing and spinning cycles sounds like it might be coming from transmittion or bearings.
sidfink43
#2 Posted : Thursday, January 14, 2010 5:17:31 PM(UTC)
sidfink43
As you might imagine it is somewhat difficult for us to properly diagnose a noise because the main way we do so is to listen to it, and try to determine the problem from the type of noise and the location. On a Forum we just cannot do that but here are some thoughts
I don't think it is likely the bearing, and I would start by changing out the belt, an easy and inexpensive fix. If that does not solve things, try to see if it is the pump. Maytag redesigned this pump, and probably had a reason to do so. The pump turns all the time so that would explain the noise in both the agitate and spin cycles.
Here is a tech bulletin on the pump.
http://www.servicematters.com/m...rary/docs/TDL-0106-B.pdf
Guest (4)
Noisy washer spin (Washer Repair)
by TomHudson 10/22/2023 8:01:49 PM(UTC)
noisy washer, but difficult to pin down (Washer Repair)
by kScottk 4/16/2023 10:00:12 AM(UTC)
noisy washer (Washer Repair)
by intimidatorwrath 7/25/2016 6:11:33 PM(UTC)
by plumber123 11/3/2013 3:56:35 AM(UTC)
Noisy Washer (Washer Repair)
by Nav5805 11/9/2011 5:12:17 PM(UTC)
Noisy washer with water pump leak (Washer Repair)
by zippy617 1/23/2011 12:20:46 PM(UTC)
Noisy washer (Washer Repair)
by jerry2083 6/26/2010 2:13:19 PM(UTC)
by william clegg 1/10/2010 6:53:11 AM(UTC)
very noisy washer at dryer cycle (Washer Repair)
by awalle 6/28/2009 11:15:21 AM(UTC)
very noisy washer (Washer Repair)
by Eric Nelson 6/26/2009 12:43:03 PM(UTC)
by worthless52 2/25/2009 9:34:31 PM(UTC)
by Blue 2/5/2009 7:41:25 AM(UTC)
Noisy washer (Dishwasher Repair)
by marsden4 6/19/2008 9:26:15 AM(UTC)
by looz98 4/4/2008 7:58:07 AM(UTC)
Noisy washer drain pump? (Washer Repair)
by mehullica 10/28/2007 10:49:41 AM(UTC)
