kvernon11
#1 Posted : Monday, December 14, 2009 6:09:37 AM(UTC)
kvernon11
Water dispenser is dripping at water&ice on door. I had to shut off supply to make drip stop. I was told the water valve (WR57X10051) needs to be replaced. Where is it located in the unit?
Qtip
#2 Posted : Monday, December 14, 2009 5:59:19 PM(UTC)
Qtip
You will have to pull the fridge out so you can get to the back of it - once its pulled out enough to get behind it then take the back cover off and follow the water line going into the back of the fridge. the part that that line connects to is the water valve
kvernon11
#3 Posted : Wednesday, December 16, 2009 7:19:59 AM(UTC)
kvernon11
thanks a lot, is it difficult to swap out?
Qtip
#4 Posted : Wednesday, December 16, 2009 5:15:57 PM(UTC)
Qtip
Not difficult at all... there will be a few screws holding the valve in place and the wires just unplug from it but make sure to plug the wires back in the same way they came off. its very easy... the only thing that can go wrong is if you mix up the wires and then when you go to get water out of the dispenser it will fill up the icemaker instead but its really easy you wont have a problem
Bosch Refrigerator Water Valve Stuttering (Refrigerator & Freezer Repair)
by Mattman928 4/14/2020 1:25:14 AM(UTC)
Water valve chatter/low output (Refrigerator & Freezer Repair)
by mmisko 2/3/2020 10:00:58 AM(UTC)
Use other water valves (Washer Repair)
by zuki1100 4/18/2019 3:53:11 PM(UTC)
Water leak after replacing water valve (Refrigerator & Freezer Repair)
by gmanly 4/13/2019 9:06:58 AM(UTC)
Voltages/Signal going to water valve (Refrigerator & Freezer Repair)
by PT2000 6/13/2017 8:14:51 AM(UTC)
Would you change water valves? (Washer Repair)
by NSXBill 3/10/2017 2:44:04 PM(UTC)
Leaking Water Valve W10340983 (Refrigerator & Freezer Repair)
by doubldc 2/9/2017 9:40:08 PM(UTC)
Hot Water valve in home (Washer Repair)
by Amana_watt? 1/19/2016 8:36:25 PM(UTC)
New GE dishwasher - leaking at water valve (Dishwasher Repair)
by cbrandel 7/29/2015 7:25:31 AM(UTC)
How to access the water valve (Dishwasher Repair)
by bradawk 3/13/2015 4:18:08 PM(UTC)
Water valve question (Dishwasher Repair)
by rich22 2/26/2015 4:51:52 PM(UTC)
ice maker water valve (Refrigerator & Freezer Repair)
by doug1512 11/23/2014 10:33:57 AM(UTC)
Jenn-Air/Whirlpool Free Standing Ice Maker Water Valve (Refrigerator & Freezer Repair)
by mjbosha 9/12/2014 4:21:51 AM(UTC)
Do I need to relpace Inlet Water Valve? How? (Washer Repair)
by rodrigt 8/14/2014 11:04:11 PM(UTC)
Dual water valve (Refrigerator & Freezer Repair)
by mikegayron 7/25/2014 8:13:55 PM(UTC)
