camorasch
#1 Posted : Monday, December 7, 2009 2:31:40 PM(UTC)
camorasch
We got this oven off of Freecycle. The previous owner had the same problem we are now having. However, I plugged it in and had no problems for 6 weeks. Then all the sudden...
The first time the oven was being used then just kept getting hotter and hotter and would not shut off. I had to throw the breaker.
Now, every time I even turn on the breaker the oven comes on. I don't touch a button. Just as soon as it has power it starts heating up. Eventually it shows the error codes E2 F3. I did some research online and replaced the oven sensor, but that didn't work. Any ideas?
#2 Posted : Tuesday, December 8, 2009 2:08:42 AM(UTC)
Replacement parts for WHIRLPOOL RF386PXGQ0 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208053302.pdf
Sounds like one of the control relay's contacts are welded together so that that element is always on.
camorasch
#3 Posted : Tuesday, December 8, 2009 8:11:50 AM(UTC)
camorasch
Can you tell me the specific part number that I need? And is this repair easy enough for a novice?
#4 Posted : Tuesday, December 8, 2009 10:55:36 AM(UTC)
The contro1 board is Item 12 in Section 2 of the parts.
This should help you with replacing it
https://secured.whirlpoo...617041/$FILE/4321893.pdf
I would check that the oven element is heating fully.
Not just a section which could be an indication of a bad element.
Unplug the unit and check the board by the look of it the relays are open.
So if the fault is that the contacts have welded themselves together you should be able to see that.
If they are not too bad you may be able to open them and then clean them with some fine emery cloth.
Kitchen Aid duel fuel oven won't turn off (Model: KDRS407VSS04) (Oven Repair (including Ranges and Cooktops))
by Guest 2/5/2024 6:06:45 PM(UTC)
oven won't turn off (Oven Repair (including Ranges and Cooktops))
by ssmith11 8/27/2012 3:39:26 PM(UTC)
Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by cap424646 5/9/2012 5:53:54 PM(UTC)
Whirlpool Double Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by jforeman 5/8/2012 7:09:34 PM(UTC)
Whirlpool Double Oven Won't Turn Off (Oven Repair (including Ranges and Cooktops))
by Bobmmm 2/7/2012 8:22:08 PM(UTC)
by oldschoolmc 1/4/2012 1:17:53 AM(UTC)
Kenmore oven won't turn off - recall (Oven Repair (including Ranges and Cooktops))
by genghiskhan 12/9/2011 11:02:28 AM(UTC)
by Debrab 6/5/2010 2:17:58 PM(UTC)
Kitchenaid Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Jane D 4/14/2010 7:01:04 PM(UTC)
by buster42 12/18/2009 4:07:01 AM(UTC)
Set-in oven won't turn off. (Oven Repair (including Ranges and Cooktops))
by tdtk42 11/6/2009 7:29:02 AM(UTC)
by danieltravagliante 7/26/2009 10:52:14 AM(UTC)
Whirlpool oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Pat LaPorte 6/24/2009 8:45:36 PM(UTC)
by JDMACRAE 6/22/2009 6:30:20 PM(UTC)
by rg99 3/2/2009 3:22:59 PM(UTC)
