raymo@57
#1 Posted : Monday, February 11, 2008 9:06:16 AM(UTC)
raymo@57
thermador Knobs will not light burners. They use to click then burner would light. The igniters would click, now we light them with a lighter. They don't click, and griddle doesn't get hot know either. thank you
#2 Posted : Monday, February 11, 2008 4:01:15 PM(UTC)
The first thing I would check is 120V at the power outlet and the plug connection.
raymo@57
#3 Posted : Monday, February 11, 2008 5:00:22 PM(UTC)
raymo@57
the electric is good the ignitor's on all 4 burners worked on and off then they went out all together. Then one day they just started woking again and then a few day's later they went out! what do you think
#4 Posted : Monday, February 11, 2008 6:53:39 PM(UTC)
Did you check the outlet or you just think it's good?
Servicer
#5 Posted : Friday, February 29, 2008 7:31:00 AM(UTC)
Servicer
Does the red light near the left side burners light up, or does gas flow from the left side burners when it's not sparking?
If not, then Gene is on the right track, and it sounds like a power supply issue. You can use and extension cord and plug it into a known-good outlet and test it. Or it could also be a simmer control starting to go bad. This component sends power to the spark module to start the sparking.
If the light does turn on every time there may be a problem with the spark module.
Whirlpool WFG505MOBS0 - Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by JeffraKing 11/15/2023 9:09:08 AM(UTC)
Thermador Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by Guest 8/1/2023 8:48:27 AM(UTC)
Frigidaire FGF366BCB Oven and Broiler won't light (Oven Repair (including Ranges and Cooktops))
by macche 8/22/2019 4:28:11 AM(UTC)
BOSCH Vision 500 Gas (NG) Dryer Model #WTVC6530UC/11 - igniter won't light, rapid clicking sound (Dryer Repair)
by KenBradley 8/11/2019 7:30:53 PM(UTC)
Gas cooktop won't light (Oven Repair (including Ranges and Cooktops))
by stephenfernandez 6/29/2019 8:40:36 AM(UTC)
Whirlpool Gas Range won't light: gas valve shuts off after 1 or 2 seconds (Oven Repair (including Ranges and Cooktops))
by Drew42TX 4/22/2019 8:23:07 AM(UTC)
Amana oven won't light (Oven Repair (including Ranges and Cooktops))
by rope13 1/10/2017 3:55:40 PM(UTC)
Gas dryer won't light (Dryer Repair)
by tseibring 12/23/2016 1:45:50 PM(UTC)
Frigidaire Oven bake option not working Igniter won't light (Oven Repair (including Ranges and Cooktops))
by mlb7412 9/30/2016 7:02:20 AM(UTC)
GE Gas Oven, both burners won't light (Oven Repair (including Ranges and Cooktops))
by AlexelA 4/7/2016 9:54:33 AM(UTC)
Help, my gas oven won't light..... (Oven Repair (including Ranges and Cooktops))
by lharrell79 3/17/2016 10:13:10 AM(UTC)
Jenn Air Gas Oven Model #JGW8130ADB Oven Ignitor won't light broiler does light (Oven Repair (including Ranges and Cooktops))
by delvarela 11/11/2015 10:40:40 AM(UTC)
Oven won't light, hear click(s), no gas smell (Oven Repair (including Ranges and Cooktops))
by gizmodyne 4/26/2015 6:36:01 AM(UTC)
Whirlpool Oven/Broiler won't light (Oven Repair (including Ranges and Cooktops))
by 67cutlass 2/27/2015 4:51:59 AM(UTC)
Kitchenaid Gas Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by Chris Ricc 1/7/2015 8:13:37 PM(UTC)
