21 Pages«<1112131415>»
HXLVRME
#121 Posted : 15 years ago
HXLVRME
i tried to reset the clock for the time change and recd the error message 5ab. maytag touchpad
#122 Posted : 15 years ago
Push and hold the Clock button for about 5 seconds or until it beeps.
HXLVRME
#123 Posted : 15 years ago
HXLVRME
Thanks So Much For The Help
#124 Posted : 15 years ago
You are welcome.
bboustany
#125 Posted : 15 years ago
bboustany
The frigidaire error codes go up to F9. Do you have any idea what F20 means?
#126 Posted : 15 years ago
Answered here: http://forum.appliancepartspros...ctric-range-cooktop.html
SimonPatrice
#127 Posted : 15 years ago
SimonPatrice
I have a JCBP40w0j2ww GE self-cleaning convection range. For a couple of months, I had been getting the F2 error quite frequently, especially when I would pre-heat the oven at 550F for about an hour. Then, I started to get the F2 pretty much anytime, even at low temps. In the last months, no more F2, the oven just shuts off anytime it feels like it.
Could just changing the temp sensor solve the problem or do I have to spend a lot more to change the whole control panel?
Also, how easy is it to do all of this myself? I've never done any electrical repair myself.
Thank you very much!
Patrice
#128 Posted : 15 years ago
Patrice,
The error code “F2” will be displayed along with a beeping sound if the ERC (Electronic Range Control) or “clock” senses a runaway heat condition during the “cook” or the “clean” modes. It could be caused by the oven temperature sensor, by the ERC or by the wire harness between the oven temperature sensor and the ERC.
The access to the oven temperature sensor plug and the wires is from the back only. You have to pull the range out of the wall. Disconnect the power and remove the rear cover. Check the resistance across the oven temperature sensor at the quick disconnect plug. It is supposed to be about 1100 Ohms at room temperature. If the resistance is incorrect, the oven temperature sensor is bad and needs to be replaced. If not, check all the wires from the oven temperature sensor to the ERC.
It is a good idea to eliminate the sensor quick disconnect plug and reconnect the sensor, using a high temperature porcelain wire nuts. Power up the range and check how the oven works.
If it's not the sensor and/or wires, replace the ERC.
- The oven sensor Part number: AP3192829
- The ERC Part number: AP3772904
- The porcelain wire nuts Part number: AP3440631
If you know how to handle a simple tools, this job is not too difficult to do it yourself and you can save a big $$$.
Here are the breakdown diagrams and Replacement parts for General Electric JCBP40WJ2WW Electric range | AppliancePartsPros.com
myamanastove
#129 Posted : 15 years ago
myamanastove
Originally Posted by: Sailn Go to Quoted Post
Thank you for the oven codes. I do not see F7-E0 under Kitchenaid.....do you have additional information??
Thank you in advance!
Hi, will you please send me the error codes for Amana Model AC5720AS
Thanks!
myamanastove
#130 Posted : 15 years ago
myamanastove
Hi will somebody please send me the error codes for Amana Model No. AC5720AS?
Thanks!
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 10 years ago
Oven Error Codes & Won't Heat Fully (Oven Repair (including Ranges and Cooktops))
by davem68 12 years ago
Whirlpool oven error codes (Oven Repair (including Ranges and Cooktops))
by ajsml 13 years ago
by fred jacoby 13 years ago
by sigman 13 years ago
kENMORE OVEN ERROR CODES E3 FI (Oven Repair (including Ranges and Cooktops))
by chrisb361 13 years ago
Whirlpool Electic oven error codes (Oven Repair (including Ranges and Cooktops))
by fcarrelli 15 years ago
Oven error codes F3 and F2 (Oven Repair (including Ranges and Cooktops))
by emidgette 15 years ago
GE Oven error codes (Oven Repair (including Ranges and Cooktops))
by BobChurch 16 years ago
GE oven error codes (Oven Repair (including Ranges and Cooktops))
by bdeinhardt@aol.com 16 years ago
Whirlpool Double Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by alaucks 16 years ago
by cndybkr 17 years ago
Additional Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by indydoug 17 years ago
