21 Pages«<1011121314>»
#111 Posted : 15 years ago
Failure codes for different models can be different. According to the Failure Codes list for PGR models, the problem most likely is a bad Electronic Range Control (ERC).
- The ERC Part number: AP3392876
cgeljones
#112 Posted : 15 years ago
cgeljones
This code is not listed under the GE built in oven. I see it under others though, is it the same?
#113 Posted : 15 years ago
Error codes are very different for different makes and models. What is the complete model number of the oven?
barbboy
#114 Posted : 15 years ago
barbboy
I just ordered a replacement controller/clock for my Maytag Oven, since the existing one kept beeping randomly and the oven would not stay on. (But no fault code)
I installed the replacement part, and within 5 minutes it showed an F1 fault. New part from this site, right out of the box. Before I exchange it for another board, is there something else that I should be checking? Is it possible that something else is making it do a F1 fault or did I just get a dud?
Maytag model MGR574ADW
Barb
#115 Posted : 15 years ago
Barb,
What is the part number of the control board you ordered?
barbboy
#116 Posted : 15 years ago
barbboy
Gene,
I ordered Part Number AP4309072 (W10162787) CNTRL-ELEC as was suggested on this board.
Barb
#117 Posted : 15 years ago
Barb,
The part number is correct and it looks like the control board is defective. They should replace it under the part warranty.
aja8888
#118 Posted : 15 years ago
aja8888
Hi Gene:
Thanks for all you are doing here helping people! :)
We have a Frigidaire electric range model GLEF378CSB and the oven is not working. No codes are thrown and the touch panel "looks" like it is working (all functions) but no heat in the oven or broiler. A tech was out several months ago and said the EOC needs to be changed out for the sum of $450!. Now, if no codes are thrown, is this a possibility?
Thanks,
Tony
#119 Posted : 15 years ago
Originally Posted by: aja8888 Go to Quoted Post
Hi Gene:
Thanks,
Tony
Tony,
Thank you for your good words.
Your question answered here: http://forum.appliancepartspros...ge-oven-not-working.html
aja8888
#120 Posted : 15 years ago
aja8888
Thanks Gene. I will get to it.
Tony
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 10 years ago
Oven Error Codes & Won't Heat Fully (Oven Repair (including Ranges and Cooktops))
by davem68 12 years ago
Whirlpool oven error codes (Oven Repair (including Ranges and Cooktops))
by ajsml 13 years ago
by fred jacoby 13 years ago
by sigman 13 years ago
kENMORE OVEN ERROR CODES E3 FI (Oven Repair (including Ranges and Cooktops))
by chrisb361 13 years ago
Whirlpool Electic oven error codes (Oven Repair (including Ranges and Cooktops))
by fcarrelli 15 years ago
Oven error codes F3 and F2 (Oven Repair (including Ranges and Cooktops))
by emidgette 15 years ago
GE Oven error codes (Oven Repair (including Ranges and Cooktops))
by BobChurch 16 years ago
GE oven error codes (Oven Repair (including Ranges and Cooktops))
by bdeinhardt@aol.com 16 years ago
Whirlpool Double Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by alaucks 16 years ago
by cndybkr 17 years ago
Additional Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by indydoug 17 years ago
