opty
#1 Posted : Wednesday, October 28, 2009 6:34:37 PM(UTC)
opty
My dryer used to have an intermittent squeal as of yesterday the drum won't turn at all. I found the motor this afternoon and there is a pulley wheel that spins when I turn it on. The belt that fits around the drum doesn't appear broken. There is also a nylon wheel that the belt goes around this is attached by a metal plate and a spring. When I move this plate to touch the drum (which is how I think it's supposed to work) nothing happens. Can anyone help me
#2 Posted : Wednesday, October 28, 2009 6:49:59 PM(UTC)
No, it does not work this way. The idler wheel is there to keep some tension on the belt so it will grip the drum.It sounds like your drum may be jammed. Try turning it in the correct direction, it should turn fairly easily.
Here is a good site with lots of info on basic dryer repair.
http://www.applianceaid.com/dryers.html
LG Dryer won't turn on, but light on inside drum. (Dryer Repair)
by pshoebri 4/22/2018 8:12:26 AM(UTC)
Frigidaire Dryer Won't Turn Off (Dryer Repair)
by candy1524 3/12/2018 2:33:20 PM(UTC)
by dibiaso22 9/15/2017 3:00:54 PM(UTC)
Help!! GE Dryer won't turn on unless you spin it (Dryer Repair)
by Ruben C 12/6/2014 4:46:28 PM(UTC)
dryer won't turn on (Dryer Repair)
by pansie 8/15/2014 3:21:29 PM(UTC)
ge dryer won't turn off when clothes are dry, just keeps running (Dryer Repair)
by lynben 3/31/2014 6:17:43 PM(UTC)
dryer won't turn on until it has cooled (Dryer Repair)
by Cam2ron2502 6/7/2013 1:43:31 PM(UTC)
Dryer won't turn on the motor or heating element (Dryer Repair)
by axnst1 3/13/2013 6:03:28 PM(UTC)
dryer won't turn off (Dryer Repair)
by budmgd 12/31/2012 9:22:25 AM(UTC)
Dryer won't turn on. (Dryer Repair)
by generic 7/24/2012 5:16:50 PM(UTC)
dryer won't turn on, also light stays on with door closed (Dryer Repair)
by mazw 7/24/2012 4:17:25 PM(UTC)
Maytag dryer won't turn on. nothing lit except light when open door (Dryer Repair)
by eprunty 6/22/2012 12:00:17 PM(UTC)
Roper dryer won't turn on need some help (Dryer Repair)
by Robdob363 2/2/2012 9:30:47 AM(UTC)
dryer won't turn on..code F01 displayed (Dryer Repair)
by leamarie 12/15/2011 5:56:44 AM(UTC)
Admiral Dryer won't turn on. (Dryer Repair)
by TheoT 11/22/2011 1:31:36 PM(UTC)
