My Maytag Ensignia wont spin after replacing water pump. Washer drains but wont spin.Think load that was in washer was out of balance. Not sure.
Groups: Expert
Tilt the machine back and rotate the large pulley CCW by hand while someone observes inside the tub. If tub isn't rotating but agitator is going back and forth, the transmission is bad.
Eric
