Ok, I am trying to replace the Transmission, pretty much have everything apart, down to last part to remove transmission, and underneath the washer is a warning label saying something about a spring and to read directions on how to disassemble..... I have no directions. It looks like I have to remove this black round assembly under the washer to get at the last three bolts holding the the black triangle bearing attached to the transmission. Help... if I undo the screws in the bottom, with the warning label, will it "F" things up? Is it gonna shoot out and take my eyes out?? I have come too far to give up now, how do I proceed to remove the transmission?
Is there anyway to safely remove the brake spring without the specialty tool? some kind of makeshift tool I can make, or something I can do safely?
Ok, I got the transmission out without any blood... replaced the transmission, now it agitates slow, but no spin, so may not have been transmission after all, any ideas?
does this thing have a clutch, or what makes it spin? there was belt wear (shavings around pulley, I attributed to transmission). The motor is running, the belts and pulleys are moving...
