LWEEKS
#1 Posted : Wednesday, August 29, 2007 10:09:02 AM(UTC)
LWEEKS
My dishwasher leaks at the bottom of the door. But, It doesn't leak everytime I use it. Any ideas?
Matt / APP Team
#2 Posted : Thursday, August 30, 2007 12:42:01 PM(UTC)
Matt / APP Team
Rank: Administration
Groups: Administrators
Maybe you have tiny bubbles......... Liquid soap will cause this and the bubbles will go up and over the door seal. After you make sure the seals are clean and seated properly, open the door a few minutes after the wash cycle starts. You should maybe see a small amount of natural bubbles in the corners but it should be minimal. If there is a lot then you probably have soap problems. Did you change soap recently? If so change back. Stop prewashing with dishsoap unless you actually get 100 % of the soap off the dishes. Check Jet-Dry dispenser make sure someone did not put liquid soap in it.
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Frigidaire fill tube leak: Is it just a bad design? (Refrigerator & Freezer Repair)
by bobhucker 6/18/2024 7:59:46 AM(UTC)
GE Top Loader Washing Machine Leaking from bottom (Washer Repair)
by Guest 6/13/2024 9:46:30 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
Water leaking from Kenmore Elite 10657789700 (Refrigerator & Freezer Repair)
by Guest 6/8/2024 12:11:48 PM(UTC)
GE Cafe drawer leak (Dishwasher Repair)
by Guest 5/26/2024 6:16:43 AM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
Ice Buildup Under Freezer Platform, Leaks into Fridge (Refrigerator & Freezer Repair)
by MochaFiend 4/2/2024 3:21:56 PM(UTC)
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern 3/20/2024 2:21:47 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
Refigrator. leaks (Refrigerator & Freezer Repair)
by celshaug 3/2/2024 8:57:46 AM(UTC)
rubber hose conector decayed and leaking. (Dishwasher Repair)
by Guest 2/25/2024 3:33:37 PM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Water reservoir is leaking and freezing (Refrigerator & Freezer Repair)
by Guest 2/24/2024 12:38:19 PM(UTC)
