AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE Top Loader Washing Machine Leaking from bottom
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello, My GE Top Loading Washing Machine GLWN2800D0WS appears fairly loose, but it seems to be leaking from a hose on the bottom back left of the drum if you're looking at the drum. Any ideas on what this part is and how to diagnose further or replace? I have included a link to a video below: https://files.catbox.moe/fhws7r.mp4Any help would be hugely appreciated.
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Thank you for your question. It is likely that either the flood hose WH41X10297 has a crack in it or it has slipped loose from the tub. A mirror or camera would need to be used to view it while there is some water in the tub to identify which has occurred.
Rank: Guest
Thanks so much. I really appreciate it.
Do you think there is too much movement in the tub?
Could the suspension rods need to be replaced?
While it is slightly noisy, the movement itself is how it should be from what it looks like.
Washer Repair
