Joined: 12/4/2022(UTC) Posts: 0  Was thanked: 1 time(s) in 1 post(s)
my fridge has a top freezer and bottom fridge compartment. water leaked into the bottom fridge. I defrosted it, but now there's water leaking into the bottom fridge again. What should I do next? Thanks for your help!
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
Wilsonjiaho, thank you for your question. Based on the information provided, the defrost drain under the evaporator is clogged up. This would need to be thoroughly cleared all the way down to the compressor section.
Fantastic! Now that I know how to fix the clogged sink, what tool do I need to clear the drain all the way down?
Joined: 5/12/2024(UTC) Posts: 0  Location: Ontario Was thanked: 10 time(s) in 10 post(s)
