fedmonds
#1 Posted : Saturday, February 27, 2010 3:51:06 PM(UTC)
fedmonds
Our maytag dishwasher seems to wash ok but it appears that it does not rinse. The dishes seem to be cleaned but have a pretty thick whit powder all over them when the dry cycle is complete. Through testing, it seems that if I turn the rinse cycle on and let the washer run, then open the door, no water is present in the tub or on the dishes. Is there a relay for the rinse that may be defective and causing the machine to not rinse? If so, where do I find the part and get a new one to replace?
Fred E.
voxhumana
#2 Posted : Tuesday, March 2, 2010 5:30:55 AM(UTC)
voxhumana
I have been experiencing exactly your problem with a Maytag PDB2430 dishwasher. I get through all wash cycles and it isn't until the rinse cycle where, like you, if I let it go the dishes are basically baked by the end of it ie foggy and white.
As I haven't been getting any replies either on this site I've been experimenting and watching the cycles closely. If I let it rest between the wash and rinse it seemed to continue to rinse OK until the last rinse cycle where it just filled and only drained. And then when I opened to stop the drain and then closed again it continued just fine. I'm thinking now some sort of overheating is occurring - there is a relay motor (only a $25 part) on my machine which I'm thinking of replacing after I clean all contacts underneath first - I'll keep you posted to see what happens.
PAVT910AWW Maytag no spin (agitates instead), no refill, no rinse, timer stops. (Washer Repair)
by owkaye 7/27/2022 5:04:45 AM(UTC)
Jumps from wash cycle to drain and spin. No rinse (Washer Repair)
by tseibring 7/9/2015 1:10:20 PM(UTC)
Kenmore washer loud schreech no rinse/spin (Washer Repair)
by backyardhockey 12/3/2014 9:16:27 AM(UTC)
No Rinse (Washer Repair)
by bigdaddyd95 7/22/2014 7:20:48 AM(UTC)
Kenmore washer No spin no rinse parts source (Washer Repair)
by mkc1962 11/10/2012 6:40:20 AM(UTC)
maytag washer no rinse cycle (Washer Repair)
by obxracer#3 11/5/2012 6:15:14 PM(UTC)
frigidaire washer no rinse why? (Dishwasher Repair)
by lucy03 3/20/2012 2:59:03 PM(UTC)
Washer, no rinse cycle (Washer Repair)
by Bob21 1/23/2012 4:45:25 AM(UTC)
amana front loader no rinse cycle (Washer Repair)
by waynes91 1/14/2012 1:13:14 PM(UTC)
No Rinse cycle (Washer Repair)
by lilhonie43 8/25/2011 2:39:08 PM(UTC)
No Rinse Water (Washer Repair)
by weg 5/31/2011 6:26:53 AM(UTC)
no rinse washer (Washer Repair)
by jerryssmith636 10/1/2010 9:25:50 AM(UTC)
No cold water and no rinse cycle (Dishwasher Repair)
by jhead 2/22/2010 4:24:19 AM(UTC)
No Rinse Cycle (Washer Repair)
by dino062959 2/12/2010 1:15:58 PM(UTC)
by rbs1324 7/22/2009 8:03:31 PM(UTC)
