My Roper well wash but then stop at rinse. I can turn the knob to spin an it well spin but no rinse. Everything works but rinse.It was leaking water in the tub so I replace the water valve an that stop leaking. But still no rinse.
I am assuming the machine goes through the wash cycle completely, fill, agitate, drain and spin. In that case the problem is likely with the timer. Replace it and see if that fixes things.
Well I replace the timer waste of money again. I replace the lid switch waste of money again. Anybody have any more ideas on my problem?
If you bought the parts from this site and they did not fix the problem you can return them.
