After the wash cycle my washer spins and drains for 2-3 seconds then stops. It continues to do this several times before reaching the next cycle leaving the tub full. Then the dial moves by itself to the next settings (permanent press, delicate, etc.) and repeats the 2-3 second pattern at each drain cycle. I checked for clogs ( I didn't take the pump apart) but found nothing. Any idea how to solve this?
Hi Ted, Most likely the problem is a bad timer. - The part number for the timer is AP244688 Gene.
