camirbaird@yahoo.com
#1 Posted : Sunday, March 23, 2008 3:15:37 PM(UTC)
From what I can tell, I need a new level switch for my washing machine. My machine over fills on the rinse cycle. Today it overfilled on the first fill cycle. Can you tell me where the level switch is located and where I can get on cheap? I would like to try and fix it myself. Any tips?
Thank you
bambiblaster
#2 Posted : Sunday, March 23, 2008 4:01:18 PM(UTC)
bambiblaster
Use a putty knife and in the front about 2 in from both corners insert it into the crack to release clips that hold top of washer... there is a thin black hose make sure this is connected to the tub in the rear left side.. if is is the water level switch is in the console... part number : AP246906
Water level switch and something else maybe? (Washer Repair)
by tomsteve 2/19/2015 1:11:10 PM(UTC)
Washer overflows - water level switch replaced - did not help (Washer Repair)
by qeisus64 12/12/2014 2:15:59 PM(UTC)
Water still not stopping after water level switch replaced (Washer Repair)
by LIsa60 5/19/2014 5:33:24 AM(UTC)
GE Washer won't stop filling even after replacing Water Level Switch (Washer Repair)
by ctvquach 1/12/2014 4:33:29 PM(UTC)
Rinse - low water level - 2 Water Level Switches... (Washer Repair)
by Aleste 1/25/2013 4:20:37 AM(UTC)
Replacing water level switch (Washer Repair)
by Socalguy84 11/21/2012 8:07:56 AM(UTC)
by dellmack 8/28/2012 7:19:10 PM(UTC)
Two water level switches bad in 12 months? (Washer Repair)
by jfwilliams3 7/26/2011 8:35:32 PM(UTC)
installing water level switch (Washer Repair)
by chrisjay 3/4/2011 5:55:11 AM(UTC)
Replaced level switch still need help (Washer Repair)
by rhix613 2/24/2011 11:19:06 AM(UTC)
by bigdanallan 1/20/2011 7:42:20 PM(UTC)
Whirlpool Calypso Water Level Switch (Washer Repair)
by diyhelp 12/20/2010 6:14:21 AM(UTC)
by bowerman 11/2/2010 6:19:03 PM(UTC)
washer---water level switch (Washer Repair)
by brian_b@mail.com 10/26/2010 12:22:27 PM(UTC)
repairing a water level switch (Washer Repair)
by repairman756 1/10/2010 11:53:05 AM(UTC)
