AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Water still not stopping after water level switch replaced
I got a water level switch from here. Replaced it correctly, and the water stops correctly on small and large loads, but not on super. The water does not stop at all on the rinse cycle, I have to turn the water off. Not sure what else is wrong with it, need some help.
Sorry that didn't fix things.
Make sure the hose to the pressure switch is clear, and if it still has the problem try changing out the water inlet valve assembly. Since you bought the part here you can return it, likewise if the valve assembly does not fix things.
The final thing to test if all else fails is the control unit, again you can order the part here and if it is not the fix you can return it.
Washer Repair
