je24995
#1 Posted : 15 years ago
je24995
My duet 9250 dryer runs through the cycle but no heat. I went through the troubleshooting in the manual but everything seems to check out ok. Could it be the ckt board? Its about $200 so I cant afford to throw parts like that at it if its not it.
TheDragon
#2 Posted : 15 years ago
TheDragon
I had same situation (passed all tests)
so I took the chance and bought the CB ($45)
they offered to take it back if that was NOT my problem
but before I sent it back - I go a heater relay ($30)
that fixed it (I am debating on returning the CB ( cause my original had a small burned resistor - common problem on my model)
not sure what failed first, the CB (if at all) or the heater relay
je24995
#3 Posted : 15 years ago
je24995
Where did u order from? i found one for $200? I even jumpered out the heater relay on the board. still wont work.
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest about a year ago
Dryer runs but no heat. (Dryer Repair)
by Elarde 10 years ago
Electric dryer runs but no heat (Dryer Repair)
by M hatcher 10 years ago
new kenmore dryer runs but no heat (Dryer Repair)
by crazyhouse 12 years ago
GE gas dryer runs but no heat. (Dryer Repair)
by rroy58 12 years ago
Dryer runs but no heat (Dryer Repair)
by barglancy 14 years ago
another "dryer runs but no heat" problem (Dryer Repair)
by Rayman812 14 years ago
Whirlpool Gas Dryer Runs But No Heat (Dryer Repair)
by cybolt 14 years ago
by sdean 14 years ago
Gas dryer runs but no heat (Dryer Repair)
by pastrychef 14 years ago
Gas dryer runs but no heat. (Dryer Repair)
by peter g 14 years ago
by glenn906 15 years ago
Frigidare gas dryer runs but no heat or ignition (Dryer Repair)
by hanzi1 15 years ago
by katyld 15 years ago
Roper,dryer runs but no heat. (Dryer Repair)
by JOE BLACK 16 years ago
