My duet 9250 dryer runs through the cycle but no heat. I went through the troubleshooting in the manual but everything seems to check out ok. Could it be the ckt board? Its about $200 so I cant afford to throw parts like that at it if its not it.
I had same situation (passed all tests) so I took the chance and bought the CB ($45) they offered to take it back if that was NOT my problem but before I sent it back - I go a heater relay ($30) that fixed it (I am debating on returning the CB ( cause my original had a small burned resistor - common problem on my model) not sure what failed first, the CB (if at all) or the heater relay
Where did u order from? i found one for $200? I even jumpered out the heater relay on the board. still wont work.
