sdean
#1 Posted : 14 years ago
sdean
what to do to troubleshoot? have wiring diagram from top cover but don't know where devices are located to test...
Ok, found them...had to take top off dryer(shops were telling me I had to take front off and remove drum). Turned out one terminal of heating element was corroded, and wire burned off. Bit of wire brushing and DeOxit, a new terminal and short splice of wire, back in business. Probably won't last very long before corrosion takes over again, so I guess I start weighing whether to buy a new element or find a cheap used dryer...
#2 Posted : 14 years ago
If you were able to make a good connection it may last a long time.
Sometimes the connection is not perfect right from the factory and as current passes through it it heats up. This causes corrosion and pitting which degrades the connection, which causes more heat and so on and so on till the connection fails.
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest about a year ago
Dryer runs but no heat. (Dryer Repair)
by Elarde 10 years ago
Electric dryer runs but no heat (Dryer Repair)
by M hatcher 10 years ago
new kenmore dryer runs but no heat (Dryer Repair)
by crazyhouse 12 years ago
GE gas dryer runs but no heat. (Dryer Repair)
by rroy58 12 years ago
Dryer runs but no heat (Dryer Repair)
by barglancy 14 years ago
another "dryer runs but no heat" problem (Dryer Repair)
by Rayman812 14 years ago
Whirlpool Gas Dryer Runs But No Heat (Dryer Repair)
by cybolt 14 years ago
Gas dryer runs but no heat (Dryer Repair)
by pastrychef 14 years ago
Gas dryer runs but no heat. (Dryer Repair)
by peter g 14 years ago
by glenn906 15 years ago
Frigidare gas dryer runs but no heat or ignition (Dryer Repair)
by hanzi1 15 years ago
by katyld 15 years ago
by je24995 15 years ago
Roper,dryer runs but no heat. (Dryer Repair)
by JOE BLACK 16 years ago
