The gas dryer runs,but no heat. The thermal fuse showed continuity The Igniter showed continuity The coil with 2 posts shows resistance of 1397 mohms The coil with the 3 posts showed 560 mohm on outside terminals, and 1365 ohms on adjacent terminals. The Flame sensor showed continuity The cycling thermostat showed continuity
There is another sensor in the exhaust duct next to the thermal fuse that I do not know what it does...It has 4 posts. The 2 outside posts show continuity. The 2 inside posts show open.
Help! ....now what do I do? -Peter
Originally Posted by: peter g  The gas dryer runs,but no heat. The thermal fuse showed continuity The Igniter showed continuity The coil with 2 posts shows resistance of 1397 mohms The coil with the 3 posts showed 560 mohm on outside terminals, and 1365 ohms on adjacent terminals. The Flame sensor showed continuity The cycling thermostat showed continuity
Help! ....now what do I do? -Peter Can someone help me please...I posted on Friday.
Peter, Does the igniter glow? If it does but the gas does not flow (even on the first time) and there is the gas to the dryer and the gas shut off valve on the back of the dryer is on then the problem most likely is a bad gas valve. - The gas valve assembly Part number: AP3094298
