pastrychef
#1 Posted : Monday, January 31, 2011 9:02:20 PM(UTC)
pastrychef
Similar to other posts that I've seen, my GE dryer will run but doesn't heat up above room temp. A few days prior to this happening I noticed a slight gas smell. I unplugged everything immediately, shut off the gas at the wall, checked the gas line for leaks (found none) and cleaned out the vent duct while that was accessible, then turned the gas back on.
Since then, no gas smell, but no heat at all either. Is this likely a heating coil or something that is easily replaced?
Thanks!
RoboJoe Industries
#2 Posted : Thursday, February 3, 2011 10:08:04 PM(UTC)
RoboJoe Industries
"Ignitor" would be the term. Or, could be a thermal fuse or flame sensor.
Can you operate a meter?
If so, you may call me at (***)***-****and I will walk you through it on the phone.
Otherwise, you will want to call a pro.
kayakcrzy
#3 Posted : Thursday, February 3, 2011 11:18:00 PM(UTC)
kayakcrzy
It sounds like the ignitor, since you smelled gas. The ignitor could be weak, and barely opening the gas valve, causes it not to light, and therefor the smell og gas. Tom ApplianceEducator.com
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
GE gas dryer runs but no heat. (Dryer Repair)
by rroy58 11/19/2012 3:07:23 PM(UTC)
Whirlpool Gas Dryer Runs But No Heat (Dryer Repair)
by cybolt 3/10/2011 8:08:45 PM(UTC)
Gas dryer runs but no heat. (Dryer Repair)
by peter g 1/7/2011 9:32:32 PM(UTC)
Frigidare gas dryer runs but no heat or ignition (Dryer Repair)
by hanzi1 5/21/2010 12:06:37 PM(UTC)
Kenmore gas dryer runs but no heat (Dryer Repair)
by Priceless999 10/27/2008 12:36:21 PM(UTC)
