stein1960
#1 Posted : Saturday, November 21, 2009 12:44:53 PM(UTC)
stein1960
The washer works fine it fills and agitates with no problems
when it gets to the spin cycle it drains all the water out but the
motor does not come on and it will not spin I removed the front cover and watched it.The motor runs fine during the wash cycle
but when it gets to the spin cycle the motor does not turn on
sidfink43
#2 Posted : Sunday, November 22, 2009 11:19:04 AM(UTC)
sidfink43
Try it with the belt off and see if the problem is the motor or the transmission.
stein1960
#3 Posted : Sunday, November 22, 2009 1:22:50 PM(UTC)
stein1960
After letting it run for a few minutes the motor did kick on and it looks like the transmission is bad I found pieces of the bearing in the bottom of the washer and it will spin if i help it to turn but then it just locks up and starts to burn the belt So I guess i'll be buying a new washer after pricing the parts to fix it
sidfink43
#4 Posted : Sunday, November 22, 2009 2:10:14 PM(UTC)
sidfink43
That is what I suspected, so good luck with your new machine.
Frigidaire Washer Won't Spin after replacing drive belt (Washer Repair)
by Shindigit 5/4/2013 10:54:15 AM(UTC)
frigidaire washer won't spin cloths dry (Washer Repair)
by MrVix 1/29/2012 12:17:20 PM(UTC)
Frigidaire Washer won't spin (Washer Repair)
by csnow 12/16/2011 8:06:42 AM(UTC)
by John Mascarena 12/12/2011 12:05:41 PM(UTC)
Frigidaire washer won't spin (Washer Repair)
by maggiemc 11/29/2011 6:39:13 PM(UTC)
Frigidaire Washer won't spin or drain (Washer Repair)
by jcutillo 8/21/2011 10:15:07 AM(UTC)
Frigidaire washer won't spin fast (Washer Repair)
by wiredmonkey 7/6/2011 9:35:37 AM(UTC)
Frigidaire washer won't spin won't drain (Washer Repair)
by janterry 2/16/2011 6:34:44 AM(UTC)
frigidaire washer won't spin out!! (Washer Repair)
by highwaystar 1/27/2010 7:56:47 PM(UTC)
Frigidaire Washer Won't Spin Out (Washer Repair)
by noley99 11/22/2009 7:13:08 AM(UTC)
by maclean 7/28/2009 11:08:42 AM(UTC)
Stackable Kenmore/Frigidaire washer won't spin (Washer Repair)
by sidevinder 5/4/2009 9:48:51 AM(UTC)
by texican 3/5/2009 5:43:41 AM(UTC)
by jwes 11/29/2008 4:55:58 AM(UTC)
by cdiscolo 12/25/2007 6:39:58 AM(UTC)
