PNW
#1 Posted : Monday, October 1, 2018 5:52:03 PM(UTC)
PNW
We recently discovered that our tub wasn't filling with hot water. The cold works fine, but when we pick a mix or hot-water wash it fills slowly and only with cold. I can feel the hot water line when it's running and it's warm so that tells me there must be some water flow, but it's not making it to the tub.
A year or so ago I changed the rubber hoses over to braided. I specifically picked hoses that didn't have the safety pressure valve. After that time it seemed like the tub filled more slowly at random times. I frankly ignored it until my wife mentioned that there wasn't any hot water on the hot-wash and sure enough that's probably what I was hearing.
Here's some troubleshooting I've attempted so far.[LIST=1]
  • Checked the flow rate from the hoses: very good.
  • Checked the hoses were connected correctly: they were.
  • Checked the screens for debris: a little bit, but nothing significant.
  • Tested the resistance of the coils: 1,000 ohms on the hot side, 1,100 ohms on the cold side.[/LIST]At this point I'm tempted to replace the mixing valve, but one of the problems I'm running into is finding parts for my model number of washer. I have a hunch that there's a parent model number and that mine is specific to the electronic control panel model.
    So I could use the following help:[LIST=1]
  • Troubleshooting ideas.
  • Help finding an equivalent model number so I can start tracking down parts.[/LIST] Thanks in advance!
  • Sponsor
    No Hot Water in Whirlpool Washer (Washer Repair)
    by Billpa2023 1/4/2023 12:12:44 PM(UTC)
    No hot water (Washer Repair)
    by scv1 12/29/2015 7:41:39 PM(UTC)
    by scv1 12/29/2015 7:39:54 PM(UTC)
    No Hot Water Coming From Inlet Valve (Washer Repair)
    by sophialh74 10/17/2014 5:37:11 AM(UTC)
    No hot water in Maytag washer (Washer Repair)
    by Pastaronie 8/16/2014 12:29:47 PM(UTC)
    by arylisrandy 10/20/2013 1:35:09 PM(UTC)
    No Hot Water in Washer (Washer Repair)
    by Obuasi 2/8/2013 4:30:18 AM(UTC)
    No Hot water (Washer Repair)
    by jeschw 8/5/2012 6:19:05 AM(UTC)
    No Hot Water Coming Into Washer (Washer Repair)
    by chloed 2/7/2012 8:08:03 AM(UTC)
    by lindaa 12/8/2011 3:39:17 PM(UTC)
    maytag washer no hot water (Washer Repair)
    by lindaa 12/7/2011 11:18:26 AM(UTC)
    Whirlpool dishwasher has no hot water or heat for drying (Dishwasher Repair)
    by ford2953 6/27/2011 5:10:33 PM(UTC)
    Whirlpool Washer - No Hot Water (Washer Repair)
    by jeff mitchell 5/20/2011 8:43:32 PM(UTC)
    by amayesin 4/30/2011 4:03:38 AM(UTC)
    Frigidaire Washer - No Hot Water (Washer Repair)
    by cdWJordan 4/8/2011 12:52:49 PM(UTC)
