Pastaronie
#1 Posted : Saturday, August 16, 2014 12:29:47 PM(UTC)
Pastaronie
Hello,
I anyone would be so kind to assist me I would greatly appreciate it. My maytag washer model mav208daww does not dispense hot water. Only cold. I have already replaced the inlet valve and it has not corrected the problem. (luckily I can return it) I have been doing some reading and seem to think it could be the temperature switch or circuit board. Anyone have any thought? Thanks for your time!!
fairbank56
#2 Posted : Saturday, August 16, 2014 1:00:02 PM(UTC)
fairbank56
Groups: Expert
Could be the temp switch or the timer. Disconnect wiring from temp switch, set to hot/cold, check continuity between terminals 17 and 19 or just jump out the orange wire and white/blue wire and see if you get hot water in wash cycle. Rinse cycle is cold only.
Eric
