allen9258
#1 Posted : 7 years ago
allen9258
Just replaced new clutch and it will spin but very slow until it stops any idea what stopping it? this also does this with the pump off.
brobriffin
#2 Posted : 7 years ago
brobriffin
Man
United States
I must imagine that it agitates at the proper speed.
When you had the trany and clutch off, did you check to see if the brake was releasing properly? If so could you spin the tub without resistance by hand using the brake release?
allen9258
#3 Posted : 7 years ago
allen9258
no i didn't check it how to check this is my question to you
allen9258
#4 Posted : 7 years ago
allen9258
this is what i think i might know how to check it but i just want to be sure pull transmission out and see if tub spins freely
brobriffin
#5 Posted : 7 years ago
brobriffin
Man
United States
yes
pull trany out
spin tub using plastic brake release
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka about a year ago
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 3 years ago
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 9 years ago
washer wont spin out (Washer Repair)
by dokratt 9 years ago
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 9 years ago
ge washer wont spin or agitate (Washer Repair)
by outback32 10 years ago
by Denarae 10 years ago
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 10 years ago
washer wont spin& drain (Washer Repair)
by aristeoherrera@gmail.com 10 years ago
washer wont spin (Washer Repair)
by lvest 11 years ago
by Mattbri 11 years ago
ge profile washer wont spin (Washer Repair)
by ron1821 11 years ago
GE profile washer wont spin (Washer Repair)
Maytag washer wont spin, smoking from under and smells like burnt rubber (Washer Repair)
by trytodiy 11 years ago
Estate Washer wont spin, not the coupling (Washer Repair)
by Greenday1827 11 years ago
