allen9258
#1 Posted : Sunday, April 8, 2018 11:08:33 PM(UTC)
allen9258
Just replaced new clutch and it will spin but very slow until it stops any idea what stopping it? this also does this with the pump off.
brobriffin
#2 Posted : Monday, April 9, 2018 7:38:12 AM(UTC)
brobriffin
Man
United States
I must imagine that it agitates at the proper speed.
When you had the trany and clutch off, did you check to see if the brake was releasing properly? If so could you spin the tub without resistance by hand using the brake release?
allen9258
#3 Posted : Monday, April 9, 2018 6:26:19 PM(UTC)
allen9258
no i didn't check it how to check this is my question to you
allen9258
#4 Posted : Monday, April 9, 2018 6:30:33 PM(UTC)
allen9258
this is what i think i might know how to check it but i just want to be sure pull transmission out and see if tub spins freely
brobriffin
#5 Posted : Monday, April 9, 2018 6:35:00 PM(UTC)
brobriffin
Man
United States
yes
pull trany out
spin tub using plastic brake release
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
by Denarae 8/4/2015 7:21:30 AM(UTC)
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 12/17/2014 12:01:09 PM(UTC)
washer wont spin& drain (Washer Repair)
by aristeoherrera@gmail.com 12/10/2014 3:19:57 PM(UTC)
washer wont spin (Washer Repair)
by lvest 7/26/2014 11:09:50 AM(UTC)
by Mattbri 5/30/2014 11:16:21 AM(UTC)
ge profile washer wont spin (Washer Repair)
by ron1821 3/24/2014 4:57:26 PM(UTC)
GE profile washer wont spin (Washer Repair)
by ron1821 3/19/2014 11:31:36 AM(UTC)
Maytag washer wont spin, smoking from under and smells like burnt rubber (Washer Repair)
by trytodiy 3/13/2014 6:20:43 PM(UTC)
Estate Washer wont spin, not the coupling (Washer Repair)
by Greenday1827 2/28/2014 3:55:12 PM(UTC)
