Hello,
my washer wont spin. I replaced the shift actuator from appliance parts pro.com, i thought that this would fix the problem since everything I have read pointed to replacing the shift actuator. But the washer still wont spin. I have done the test for error codes and all the codes came up F0 E0. The washer fills with water and drains but when it comes time to spinning, I can hear it trying, but nothing happens. Im very frustrated, I dont want to throw out my washer if its something simple to fix. But I cant afford to pay $180 just to have someone come out and just look at it. please help with any ideas. Thank you.
Sorry I should've said that the washer will fill with water But it won't agitate or spin It will drain but nothing happens during the wash Cycle or spin cycle
If you here a humming noise but it is not agitating or spinning it could be the capacitor. It is the black can looking device near the motor. You will need a electrical multi meter that reads capacitance. Look for videos on how to check a capacitor on Youtube.
