hI All, My front loading washer stopped spinning, showing error code E47. As instructed i checked the OHMS which were not at the recommended 1500 level. The guide recommended replacing the Door latch assy or control board. I ordered and replaced the door latch assy resulting in a new error, E43, which says replace control Panel, plus 4 beeps indicating that there is a problem with the door (prior to replacing the Latch Assy it would run and not spin, now it wont run at all). Should i go ahead and replace the control panel? Has any one seen this before? Any help would be great.
I have same problem. Replace door lock switch; did not help. Replaced control panel; did not help. Now have code 58. Then checked motor resistance OK. Have ordered motor speed control. Comes in Monday. I'll let you know if corrected problem.
