Mattbri
#1 Posted : Friday, May 30, 2014 11:16:21 AM(UTC)
Mattbri
hI All, My front loading washer stopped spinning, showing error code E47. As instructed i checked the OHMS which were not at the recommended 1500 level. The guide recommended replacing the Door latch assy or control board. I ordered and replaced the door latch assy resulting in a new error, E43, which says replace control Panel, plus 4 beeps indicating that there is a problem with the door (prior to replacing the Latch Assy it would run and not spin, now it wont run at all). Should i go ahead and replace the control panel? Has any one seen this before? Any help would be great.
johnwillie
#2 Posted : Saturday, May 31, 2014 7:05:32 AM(UTC)
johnwillie
I have same problem. Replace door lock switch; did not help. Replaced control panel; did not help. Now have code 58. Then checked motor resistance OK. Have ordered motor speed control. Comes in Monday. I'll let you know if corrected problem.
Mattbri
#3 Posted : Sunday, June 1, 2014 3:28:55 AM(UTC)
Mattbri
thanks Johnwillie!
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
by Denarae 8/4/2015 7:21:30 AM(UTC)
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 12/17/2014 12:01:09 PM(UTC)
washer wont spin& drain (Washer Repair)
by aristeoherrera@gmail.com 12/10/2014 3:19:57 PM(UTC)
by lvest 7/26/2014 11:09:50 AM(UTC)
ge profile washer wont spin (Washer Repair)
by ron1821 3/24/2014 4:57:26 PM(UTC)
GE profile washer wont spin (Washer Repair)
by ron1821 3/19/2014 11:31:36 AM(UTC)
Maytag washer wont spin, smoking from under and smells like burnt rubber (Washer Repair)
by trytodiy 3/13/2014 6:20:43 PM(UTC)
Estate Washer wont spin, not the coupling (Washer Repair)
by Greenday1827 2/28/2014 3:55:12 PM(UTC)
