trytodiy
#1 Posted : 11 years ago
trytodiy
Hi all. Hoping someone can help diagnose. My daughter overloaded my washer and it squealed, smelled like burning rubber, was smoking and did not spin out. The water drained though. In taking it apart, we found a sock between the two tubs. Removed the sock, changed the drive belt, and the washer agitates, but during spin smokes from underneath and smells like rubber. What else might be a problem? :confused: :(
#2 Posted : 11 years ago
Check for a sock in the pump.
trytodiy
#3 Posted : 11 years ago
trytodiy
how do I check the pump?
#4 Posted : 11 years ago
Tilt the washer back and check the pump pulley on the right, might be stuck.
