My GE Profile stopped cooling. I looked over the unit. The evaporator fan is spinning and the coils have not frosted over. The condenser fan is spinning but the compressor itself does not seem to be turning on. I checked the terminal tabs on the compressor start relay and I have no voltage. Can I check if the control board is outputting voltage to start the compressor?
