Hi everyone..
I am having aproblem with my dryer. It is an older Maytag. Here is the deal.
The dryer does not heat up.. When I turn it on, the flame does come on for about 10 seconds, then shut off. then a few minutes will pass.. and once again the flame comes on for about 10 seconds, then shut off. this is not enough to heat the clothes.
Also, if I put the dryer in auto mode. it does not cycle down. it stays in the same spot. however, if i use timed drying, the timer does work.
so far, i have changed out the cycling thermometer.. i have also changed out the coils.. two of them.. still no luck..
any thoughts. thanks brian
