bkopacz
#1 Posted : Monday, November 2, 2009 1:05:29 PM(UTC)
bkopacz
Hi everyone..
I am having aproblem with my dryer. It is an older Maytag.
Here is the deal.
The dryer does not heat up.. When I turn it on, the flame does come on for about 10 seconds, then shut off.
then a few minutes will pass..
and once again the flame comes on for about 10 seconds, then shut off.
this is not enough to heat the clothes.
Also, if I put the dryer in auto mode. it does not cycle down. it stays in the same spot.
however, if i use timed drying, the timer does work.
so far, i have changed out the cycling thermometer.. i have also changed out the coils.. two of them..
still no luck..
any thoughts.
thanks
brian
#2 Posted : Monday, November 2, 2009 2:55:26 PM(UTC)
Brian,
Most likely the problem is an obstructed dryer vent and/or clogged air ducts inside the dryer and the blower wheel.
Here are the breakdown diagrams and Replacement parts for MAYTAG LDG490 | AppliancePartsPros.com
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
electric whirlpool dryer not heating up (Dryer Repair)
by jumpnchuck 10/30/2013 6:31:51 PM(UTC)
Estate dryer not heating up (Dryer Repair)
by Jackier 8/6/2013 5:23:00 PM(UTC)
Amana Dryer not heating up after we moved into new home (Dryer Repair)
by clr0221 7/10/2013 5:33:00 PM(UTC)
frigidaire gallery series dryer not heating up (Dryer Repair)
by Oblivion 4/27/2013 7:56:33 AM(UTC)
Whirlpool dryer not heating up (Dryer Repair)
by MKrieck 7/22/2012 6:37:03 PM(UTC)
by moorece8 5/9/2012 5:28:21 AM(UTC)
Whirlpool Dryer Not heating up (Dryer Repair)
by rrussell@erols.com 4/25/2012 12:18:22 PM(UTC)
Kenore dryer not heating up (Dryer Repair)
by Thog137 11/16/2011 9:56:09 AM(UTC)
Maytag Dryer not heating up properly (Dryer Repair)
by BobG68 10/23/2011 11:45:22 PM(UTC)
Stackablw dryer not heating up/ (Dryer Repair)
by hayatsinc 5/14/2011 3:11:46 PM(UTC)
roper dryer not heating up help (Dryer Repair)
by heather608 3/18/2011 5:01:11 PM(UTC)
by scoffman1234 3/16/2011 1:36:37 PM(UTC)
Amana electric dryer not heating up (Dryer Repair)
by Ultraman50 1/6/2011 6:58:54 PM(UTC)
Maytag electric dryer not heating up (Dryer Repair)
by jmlpa 12/7/2010 9:41:11 AM(UTC)
