When our dryer doesn't function well (or doesn't actually dry at all), is there something wrong with it and what might be the problem?
A make and model would help. Find your model number - AppliancePartsPros.comOften this is caused by a partially clogged vent system. If you are sure that it does not heat at all then it con be many things like a blown heater, power to the unit, a bad thermostat/fuse and several other possibilities. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  It's a whirlpool WED4815EW. Can we check the vent system ourselves? we're afraid to do so since we might end up making the problem worse
Yes you can check it.
Unplug the unit and disconnect it from the vent system. Now try a run. If it now dries OK odds are the vent system needs checking/cleaning. Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house. Take a pair of pantyhose. Put one leg into the other and then attach this to the dryer's vent. Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the |
