BraxLimbo
#1 Posted : Thursday, November 12, 2015 11:08:58 PM(UTC)
BraxLimbo
When our dryer doesn't function well (or doesn't actually dry at all), is there something wrong with it and what might be the problem?
#2 Posted : Friday, November 13, 2015 1:08:41 AM(UTC)
A make and model would help.
Find your model number - AppliancePartsPros.com
Often this is caused by a partially clogged vent system.
If you are sure that it does not heat at all then it con be many things like a blown heater, power to the unit, a bad thermostat/fuse and several other possibilities.
BraxLimbo
#3 Posted : Thursday, November 19, 2015 11:13:39 PM(UTC)
BraxLimbo
It's a whirlpool WED4815EW. Can we check the vent system ourselves? we're afraid to do so since we might end up making the problem worse
#4 Posted : Friday, November 20, 2015 3:26:52 AM(UTC)
Yes you can check it.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the
BraxLimbo
#5 Posted : Tuesday, November 24, 2015 10:27:12 PM(UTC)
BraxLimbo
Thanks a lot!
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
LG dryer not drying clothes (Dryer Repair)
by DGRA0005 7/6/2020 5:42:51 PM(UTC)
Whirlpool wed4800bq1 dryer not drying very good (Dryer Repair)
by t3i 3/19/2019 3:10:19 PM(UTC)
Dryer not drying (Dryer Repair)
by Scotty dog 12/3/2017 10:46:30 AM(UTC)
Dryer not Drying Clothes (Dryer Repair)
by Epfever1 12/1/2017 9:44:44 AM(UTC)
dryer not drying and water in drum (Dryer Repair)
by sonjawainwright 8/23/2017 8:07:12 AM(UTC)
Matag Dryer not drying in Intellidry Mode (Dryer Repair)
by themooser98 8/23/2017 5:43:28 AM(UTC)
maytag centennial electric dryer not drying/heating anymore (Dryer Repair)
by lloyd raymond martin 6/7/2017 5:34:16 PM(UTC)
Maytag Centennial Dryer not drying completely. (Dryer Repair)
by bryanakers 10/10/2016 5:42:01 AM(UTC)
My Dryer not drying (Dryer Repair)
by anikabrown 3/29/2016 3:57:03 AM(UTC)
Roper Dryer not drying (Dryer Repair)
by fhorta 11/3/2015 5:28:30 AM(UTC)
Samsung dryer not drying/get hot (Dryer Repair)
by Mommydearest819 5/30/2015 3:31:39 AM(UTC)
LG Tromm Dryer not drying (Dryer Repair)
by earcaesar 3/26/2015 5:50:26 PM(UTC)
Whirlpool elec. dryer not drying (Dryer Repair)
by Don Akina 3/19/2015 8:34:45 AM(UTC)
