My GE Profile with bottom freezer is not dispensing water or making ice. I thought it was originally the water inlet valve, so I replaced it. I have good flow of water to the inlet valve, and I can blow air from inlet valve hoses to dispenser and ice maker so it is not frozen. I am not getting any clicking noises at the Dispenser Control Board, I assume my next two choices will be to either replace the Dispenser Control Board or the Main Board. I got the Escutcheon cover pryed back from the bottom of the unit up to the dispenser control board, but then it seems stuck, and I can't figure out for the life of me how to remove the dispenser control board......or don't you guys think this is my problem. Please help. Thanks!  deuce73 attached the following image(s):
...Now the ice maker is working....but still no water at door dispenser.
