BraxLimbo
#1 Posted : 9 years ago
BraxLimbo
When our dryer doesn't function well (or doesn't actually dry at all), is there something wrong with it and what might be the problem?
#2 Posted : 9 years ago
A make and model would help.
Find your model number - AppliancePartsPros.com
Often this is caused by a partially clogged vent system.
If you are sure that it does not heat at all then it con be many things like a blown heater, power to the unit, a bad thermostat/fuse and several other possibilities.
BraxLimbo
#3 Posted : 9 years ago
BraxLimbo
It's a whirlpool WED4815EW. Can we check the vent system ourselves? we're afraid to do so since we might end up making the problem worse
#4 Posted : 9 years ago
Yes you can check it.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the
BraxLimbo
#5 Posted : 9 years ago
BraxLimbo
Thanks a lot!
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 about a year ago
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 4 years ago
LG dryer not drying clothes (Dryer Repair)
by DGRA0005 5 years ago
Whirlpool wed4800bq1 dryer not drying very good (Dryer Repair)
by t3i 6 years ago
Dryer not drying (Dryer Repair)
by Scotty dog 7 years ago
Dryer not Drying Clothes (Dryer Repair)
by Epfever1 7 years ago
dryer not drying and water in drum (Dryer Repair)
by sonjawainwright 8 years ago
Matag Dryer not drying in Intellidry Mode (Dryer Repair)
by themooser98 8 years ago
maytag centennial electric dryer not drying/heating anymore (Dryer Repair)
by lloyd raymond martin 8 years ago
Maytag Centennial Dryer not drying completely. (Dryer Repair)
by bryanakers 8 years ago
My Dryer not drying (Dryer Repair)
by anikabrown 9 years ago
Roper Dryer not drying (Dryer Repair)
by fhorta 9 years ago
Samsung dryer not drying/get hot (Dryer Repair)
by Mommydearest819 10 years ago
LG Tromm Dryer not drying (Dryer Repair)
by earcaesar 10 years ago
Whirlpool elec. dryer not drying (Dryer Repair)
by Don Akina 10 years ago
