mlsmith18
#1 Posted : Monday, November 9, 2015 5:19:08 PM(UTC)
mlsmith18
The 8" large surface element remains full on irregardless of where the temperature select dial is positioned. The element does not "cycle" depending upon the dial position. The element does shut off when the dial is in the "off" position.
#2 Posted : Tuesday, November 10, 2015 1:15:35 AM(UTC)
I cannot find any info on the given model number.
Please check it.
I tried here, Sears and GE.
In any case I would replace the infinite switch.
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
Whirlpool electric range GR563LXSS (Oven Repair (including Ranges and Cooktops))
by longtimealaskan 3/6/2023 9:47:00 PM(UTC)
Samsung electric range bake and broil do not work (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 2:07:19 PM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Westinghouse Electric Range Model KF341R (Appliance Parts)
by GEman 5/28/2022 9:09:03 AM(UTC)
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
Frigidaire LGEF3043KFM Electric Range Uneven Heat (Oven Repair (including Ranges and Cooktops))
by Asweateria 2/27/2022 9:32:41 PM(UTC)
Samsung electric range (Oven Repair (including Ranges and Cooktops))
by MELLIOTT 2/8/2022 6:38:17 AM(UTC)
LG Electric Range Overheating (Oven Repair (including Ranges and Cooktops))
by jenvee 1/25/2022 7:20:52 AM(UTC)
kenmore electric range 79097459802 (Oven Repair (including Ranges and Cooktops))
by Melissadimas 1/9/2022 9:07:08 PM(UTC)
replacing latch, door on Kitchen Aid electric range series II (Oven Repair (including Ranges and Cooktops))
by WSCHUMANN 7/12/2021 6:02:36 AM(UTC)
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 5/7/2021 9:58:17 AM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
