pecosb1
#1 Posted : Wednesday, August 19, 2015 7:25:20 PM(UTC)
pecosb1
During the fill cycle, water does not shut off when tub is full, washer overflows.
fairbank56
#2 Posted : Thursday, August 20, 2015 5:55:35 AM(UTC)
fairbank56
Groups: Expert
With washer empty, open the front panel, disconnect the pressure hose from the air chamber on the lower left side of the tub and clean out any gunk in the hose. Use a turkey baster with hot water to flush out the air chamber of any gunk as well. The air chamber is not removable.
Eric
pecosb1
#3 Posted : Saturday, August 22, 2015 1:45:27 PM(UTC)
pecosb1
Thanks, you were on the money......hose was plugged with junk for about 6 inches.....cleaned it all out, washer works fine again!
Washer overflows - water level switch replaced - did not help (Washer Repair)
by qeisus64 12/12/2014 2:15:59 PM(UTC)
GE washer overflows after agitation unless extra small load WCXR1070TAWW (Washer Repair)
by Larry75243 9/16/2013 11:10:36 AM(UTC)
washer overflows on xlarge load only (Washer Repair)
by FRVMAN 9/1/2013 6:33:24 AM(UTC)
Kenmore Dishwasher overflows to the floor (Dishwasher Repair)
by goingjumping 2/17/2013 3:03:47 PM(UTC)
washer overflows and unbalance load displayed (Washer Repair)
by allen9258 1/27/2013 7:41:58 AM(UTC)
Maytag Washer overflows on rinse only (Washer Repair)
by basgetar 5/9/2012 5:40:29 PM(UTC)
Washer Overflows Except with Cold Water (Washer Repair)
by jimponti 1/15/2012 5:43:01 PM(UTC)
Dishwasher overflows when using sink (Dishwasher Repair)
by Phil69 12/30/2011 3:51:49 PM(UTC)
Maytag washer overflows during agitation (Washer Repair)
by TexasTaylors 5/28/2011 8:18:42 PM(UTC)
Washer overflows AFTER 1st agitation (Washer Repair)
by Huff360 10/4/2010 6:36:29 AM(UTC)
GE Washer Overflows (Washer Repair)
by vbiondillo@norhill.net 8/3/2010 12:53:03 PM(UTC)
Washer overflows - sometimes (Washer Repair)
by psunittanylion 7/6/2010 9:48:24 AM(UTC)
Washer overflows when set at large load (Washer Repair)
by Victor Scott 6/7/2010 9:46:52 AM(UTC)
Kenmore washer overflows on rinse cycle (Washer Repair)
by montani 5/18/2010 12:00:23 PM(UTC)
Roper washer overflows (tried everythinhg) (Washer Repair)
by tbone47978 3/16/2010 4:17:41 PM(UTC)
