Roncf
#1 Posted : Tuesday, October 20, 2009 6:19:20 AM(UTC)
Roncf
My dryer just stopped working, I can't get it to come on. I checked the plug and the wire to the dryer and check to see if I was getting power to the motor which I am. I check the door switch, it is ok. But I'm thinking it is the motor since I have power to it, but it won't come on.
Frank / APP Team
#2 Posted : Tuesday, October 20, 2009 8:42:38 AM(UTC)
Frank / APP Team
Between which two wires were you getting power? Below should get you to the wiring diagram. An open thermal fuse will give you a no run symptom.
Wiring information replacement parts for MAYTAG PYE2300AYW | AppliancePartsPros.com
Roncf
#3 Posted : Tuesday, October 20, 2009 6:24:37 PM(UTC)
Roncf
I got it from the two red wires going to the motor. Where is the fuse you are talking about, where is it located and what does it look like? I have looked at the wiring diagram and I can't figure out where it is or what it looks like.
Frank / APP Team
#4 Posted : Wednesday, October 21, 2009 7:15:39 AM(UTC)
Frank / APP Team
The two red wires are actually for the heating circuit. They complete a circuit to make sure the heater only comes on when the motor is running.
The thermal fuse is located on the heater element. Below are pictures. They are are sold as a kit with the high limit. If you have a ohm meter you can check them out. They should read closed. Once you get the top lifted you should be able to see them.
Part number: AP4242472
Maytag Dryer shutting off after 2 minutes (Dryer Repair)
by Guest 11/9/2023 4:45:11 AM(UTC)
maytag dryer MEDC200XW1 (Dryer Repair)
by patnok 9/4/2023 8:02:13 AM(UTC)
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
Maytag dryer (Mode MEDC300XW1) not starting, but runs only in Wrinkle Prevent cycle. (Dryer Repair)
by Guest 7/28/2022 6:31:22 PM(UTC)
Maytag dryer won't stop on timed dry (Dryer Repair)
by eaglemtn 11/11/2021 5:35:16 PM(UTC)
Maytag Dryer Slow to Spin after parts replacement (Dryer Repair)
by steelwindmachine 8/18/2021 5:58:15 AM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
Maytag dryer MDE9316ATA (Dryer Repair)
by Guest 5/1/2021 3:45:42 PM(UTC)
Maytag Dryer (Bravos) (Dryer Repair)
by Kap61 3/29/2021 4:03:51 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
Maytag Dryer Starts But No Heat (Dryer Repair)
by boonie785 6/1/2020 3:32:33 PM(UTC)
Maytag dryer stops early (Dryer Repair)
by J-fixtit 5/28/2020 6:59:15 PM(UTC)
Maytag dryer dont start (Dryer Repair)
by jzemer 5/16/2020 5:58:30 PM(UTC)
MAYTAG dryer loud squealing/squeaking (Dryer Repair)
by joenobodyyet 3/24/2020 1:27:25 PM(UTC)
