How do I replace the temperature sensor? I can see that it unscrews from inside the oven, but how do I get to the cable behind it to unplug it? Is there a service manual for this oven? I have the owners manual.
I found end of sensor cable behind the electric oven and under sheet metal cover. How do I determine sensor is faulty? I could remove the sensor and subject to a known temperature and then measure voltage or resistance. I do not want to buy another sensor if it is not the problem.
The oven stays on about 15 minutes then turns off. I can turn it back on, but it will only stay on for a shorter time. Next time it turns off immediately. I am getting no error codes. The oven temperature is close to accurate. Same behavior with the broiler. Cleaning function does not work at all.
THIS FORUM IS DEAD!!!!!!! |
